DIPSTICK - NCRS Discussion Boards
DIPSTICK
  • Martin N.
    • July 30, 2007
    • 594
    DIPSTICK
    Anyone have the length of a C-3 Turbo 400 trans dipstick? Mine just peeks out at the bottom of the fill tube. Not sure if that's right. THANKS....Marty
  • Loren L.
    • April 30, 1976
    • 4104
    Re: DIPSTICK
    Let's see...C3 takes in 15 years and who knows how many engines...somebody measure them all and provide an "average".....
      • 15601
      Re: DIPSTICK
      You are right Loren, but his Turbo 400 request limits it somewhat more. I don't know if there is a BB v SB difference. Probably someone who is good with a parts book, or parts computer might be able limit our search further.
      • Mike E.
        • February 28, 1975
        • 5138
        Re: DIPSTICK aka Dennis C.
        By the heading, I thought you were looking for Dennis Clark!!
          • 43221
          Re: DIPSTICK
          Terry------
          There was no difference between small blocks and big blocks relative to the THM-400 dipstick and tube. However, there were differences over the years of the THM-400 use in Corvettes. There were 2 different dipsticks used over the 1968-73 period, although they are functionally interchangeable. The 72-73 PRODUCTION (which became SERVICE for 68-71) dipstick, GM #1239014, remains available from GM for about 7 bucks, GM list.
          The 73-76 dipstick was different. However, it was also used in conjunction with a different tube. The original dipstick is discontinued but its successor, GM #10017293, remains available, also for about 7 bucks, GM list.
          Unfortunately, I do not have any specs on the above dipsticks.
          No THM-400 was used in Corvettes after 1976.
            • 43221
            Re: DIPSTICK
            Marty-----
            Well, with a little more research I may have figured this one out. The 1968-73 THM-400 dipstick tube is 23" long. From what I can determine, the 1968-73 dipstick is 24-1/4" long. For 74-76, I know not.
              • 43221
              Addendum
              Marty-----
              Well, I know a little more now. The 74-76 THM-400 dipstick should be 27-5/16" long. I still don't know the length of the tube. Yet.
              • Martin N.
                • July 30, 2007
                • 594
                Re: Addendum
                SORRY! I'll be more specific in my posts. The info. I'm seeking is regarding to a 1974 Corvette (C-3) with the standard L-48 (350 c.i.) small block engine.
                THANK-YOU JOE!....Marty
                  • 43221
                  Re: Addendum
                  Marty-----
                  Let us know how the length of your dipstick compares to the dimension I provided.
                  • Martin N.
                    • July 30, 2007
                    • 594
                    Re: Addendum
                    JOE, I REALLY appreciate your time, I'm glad you got me this measurement. The one I have currently is 26 1/8" long. My trans code is: "74 CK 443" which is correct for my car. So now with this dipstick being over an inch short I can understand why my trans leaks badly, I'm overfilling it and maintaing the improper fluid level. Some time over the years someone has switched out the dipstick (and maybe the tube?). Next question is the proper length of both tube & dipstick. It would be interesting to see if this dipstick is out of a 350 trans. THANKS for all your help Joe....Marty
                    • Harmon C.
                      • August 31, 1994
                      • 3228
                      Re: Addendum
                      Marty
                      All turbo 400's that I have owned have leaked some worse than others even if rebuilt. One way to see if your dipstick is too long is let it leak till the trans won't shift and see what your gage reads. With a bad leaker it won't shift when two quarts low but one quart will make it so it can be moved from one garage bay to another.
                      Lyle
                      Lyle
                        • 43221
                        Re: Addendum
                        Marty------
                        I wouldn't recommend that you necessarily decide that your dipstick is incorrect just because of the variance in the dimension. The 27-5/16" spec that I mentioned is a GM spec. HOWEVER, GM has been known to publish these specs in terms of DEVELOPED LENGTH (developed length is the length the piece would be if all the bends, curves, and "waves" were "flattened out"). I don't THINK that's the case with this GM spec since it would make no sense, at all, to specify length in terms of DEVELOPED length, but that doesn't mean, for sure, that they didn't.
                        The first thing I would do is to go down and order a GM #10017293. Then, you will know that you will have a correct length dipstick, assuming that the tube is correct. It's much more likely that the dipstick has been replaced than it is that the tube has been changed. The dipstick only costs about $7, GM list, so you won't have a big investment here.
                        The original tube, GM #340659, is discontinued and I can't find any supercession. However, there may be one. Just ask you dealer to check for supercessions for this number. If there is a supercession, I'd buy it just to confirm that the tube you have now is correct. While it may differ in some way from the original, I don't think that the length will be different. Of course, that assumes that there even is a supercession. The tubes sell for about 20 bucks, GM list, so this shouldn't be an expensive piece, either.
                        If you try the above, let us know how it all turns out. Feedback is important on a discussion board and it's too often forgotten.
                        • Harmon C.
                          • August 31, 1994
                          • 3228
                          Re: Addendum
                          Marty
                          I would have thought someone with a 74 would have measured his dipstick for you but few who post here own 74's I guess. Try a post on Corvette Forum in the C-3 section as they have lots of posters with 74's and you may get a few answers before you buy a new dipstick.
                          Lyle
                          Lyle
                          • Martin N.
                            • July 30, 2007
                            • 594
                            Re: Addendum
                            Joe & Lyle,
                            I will follow both of your suggestions. For $7.00 it'll be worth getting a new "clean" dipstick. I'll also post the question on the "corvette form". When I do get some answers I'll post my finding here. I could not agree with you more Joe, feed back and posted results are important to this community.
                            I hope to see more mid to late 70's related posts in the future, after all, "The more the meerier".
                            Thank-you both....Marty
                              • 43221
                              Re: Addendum
                              Marty-----
                              Also, you might check the blade of the old dipstick for a part number. SOMETIMES, there will be a part number to be found. Not as often as there should be, but sometimes. If there is a part number, I could probably get a lot more definitive information on it. The number might even be a derivative of the complete part number, so if you can find any numbers, at all, that might be useful (unless it's only a single digit).
