67 headlight warning lamp update - NCRS Discussion Boards
  • Wayne K.
    • December 1, 1999
    • 1030
    With the help of members of this board I found the source of my non functioning headlight warning lamp. I traced it to the firewall plug to the fuse box. After removing the plugs (took them both off to inspect and clean with electrical parts cleaner) I found that the pin for this circuit on the fuse box side was partially bent over and pushed in thus no contact. I pulled it out and straightened it with a pliers. Cleaned things up and plugged things back together and the circuit now functions. All I need now is to get a 257 bulb as the one in there was not a flasher. I couldn't find a GE one but one local supplier has a Wagner 257. Are all 257 bulbs regardless of brand flashing bulbs?
    Thanks again to all that responded.
    Wayne
  • Mike E.
    • February 28, 1975
    • 5138
    Re: 67 headlight warning lamp update
    Yes, a Wagner 257 will be fine.
    • Gary J.
      • April 1, 1980
      • 1242
      Re: mid year windshield
      I would check and make sure the pins on the Wagner will seat good in the socket. You don't want to have to this job twice.
      Gary Jaynes
      #3503
      • Gerard F.
        • June 30, 2004
        • 3806
        Wayne,
        After you get the 257 bulb in and working, make an appointment to see your chiropractor I did.
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
