1971 CORVETTE 454/425 - NCRS Discussion Boards
  • MICHAEL #48358
    I HAVE A 1971 CORVETTE, IT'S MOTOR WAS CHANGED, IT IS A 454. HOW CAN YOU TELL WHAT THE ORIGINAL MOTOR WAS. THE AUTO STICK SHIFT CONSOLE READS 454/425HP, BUT THAT COULD HAVE BEEN CHANGED. IS IT POSSIBLE TO TELL FROM THE VIN#, OR IS THERE SOMEWHERE ON THE FRAME OR BODY THAT THIS COULD BE FOUND. THANKS FOR YOUR HELP.
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: 1971 CORVETTE 454/425
    Pleas turn off your CAPS. What is the redline on the tach? Also inside the engine compartment on the firewall behind the brake booster/master cylinder should be a white sticker with information on setting the timing and idle should tell what engine it is. That should get you started find the redline on the tachometer and the sticker and report back on them. Thanks
    Kelly
    • Warren F.
      • December 1, 1987
      • 1516
      Michael,
      I've sent you an email.
      • MICHAEL #48358
        Thanks everyone for your quick responses, I will be doing some investigation with answers I received and will get back to everyone with what I find. Thanks Michael
