'60 motor mount/water pump - NCRS Discussion Boards
  • Matt F.
    • June 30, 2002
    • 79
    Has anyone successfully used a 61-62 motor mount (the one with the notch on top) to allow installation of an aftermarket water pump on a 58-60 car? Alternately, is there a water pump (aside from a rebuilt original) that will fit underneath the stock motor mount for a 58-60 car?
  • Mike E.
    • February 28, 1975
    • 5139
    Re: '60 motor mount/water pump
    I believe that the just-about-most-common water pump around, the 608, will fit underneath the stock motor mount. There is no boss on the top of that one.
    • Matt F.
      • June 30, 2002
      • 79
      Hi Mike -
      Is that a Delco P/N?
      -Matt
      • Jim Mitchell
        Matt,
        I have a 1960 Corvette and have been using the '61-'62 motor mount for over 25 years with no problems encountered. Keep in mind that Chevrolet made the '61-'62 motor mount the SERVICE replacement for the earlier version.
        • Matt F.
          • June 30, 2002
          • 79
          Thanks for the info Jim. Are you able to use the newer water pumps with the boss (hump) on the top with that motor mount?
          -Matt
          • Jim Mitchell
            Matt,
            I'm using the '62 style pump with an elbow fitting/hose connecting to the '62 supply tank. A previous owner had converted to a complete '62 radiator and supply tank set-up.
            • Todd A.
              • February 1, 2002
              • 19
              Matt,
              On my '58 I am using the 61-62 style bracket with the currently offered aluminum water pump from GM Performance parts. I had to grind approx 1/4" off the front of the hump/boss to clear the bracket. Additionally I had to press the pulley boss approx 3/16" further down the shaft to bring the belt pulley into alignment with the crank pulley. Also I was fighitng leaks for awhile between the bracket and the block. I believe the aluminum with its expansion rate was compressing the gaskets over multiple heat cycles and eventually opening a leak path. Using fel-pro water pump gaskets and permatex non-hardening sealer I finally conquered the leak problem. Email me if you would like me to send any pictures.
                • 43241
                Matt-----
                Mike is referring to the GM CASTING NUMBER 3782608 water pump. This is a VERY common casting and can be found on many rebuilt waterpumps. However, it has been out-of-production for about 35 years, so you can't purchase a NEW waterpump which uses this casting (unless someone is reproducing them and I'm unaware of that at the present time). All of the NEW waterpumps on the market that I have seen do have the upper boss which will create interference problems for your application.
                However, you should be able to get a very high quality rebuilt pump which uses the 3782608 casting. Bill Mock who advertises in the Driveline can help you.
