Vacuum hose kit and diagram for C-3 - NCRS Discussion Boards
  • David B.
    • June 30, 2002
    • 30
    Hello - I am replacing the vacuum lines on my 71 and would like to know who sells the most accurate kit as far as correct hose length, wall thickness and molded ends. Are the routing diagrams correct? I have heard that some are not accurate. Any help would be greatly appreciated. Thanks Dave
  • Dick W.
    • 10483
    Re: Vacuum hose kit and diagram for C-3
    Dr Rebuild has that market cornered. His are the closest repros out there and his drawings are correct
    Dick Whittington
    • Tom H.
      • May 31, 2003
      • 89
      I bought the kit from Dr Rebuild for my 72, and it was excellant. Good fit and looked very similar to the originals I replaced.
      • Anthony S.
        • April 3, 2008
        • 183
        Dave,
        I agree.......Doc's color Vacuum Diagram is very good.
        You should also order the Oh So E-Z wiring diagrams too, they are great & even use actual pictures of each connector.
        Anthony
        • David B.
          • June 30, 2002
          • 30
          Hello - Thanks everyone for the information. I am calling the Doc tomorrow.
          Thanks Dave
          • Clem Z.
            • January 1, 2006
            • 9427
            don't use the 800# to ask questions as doc is getting older and it is tought on his heart.
            • Kent K.
              • December 1, 1982
              • 1139
              Dave,
              If you're going to Old Town, Kissimmee, Doc will be there with limited merchandise. He'd probably be happy to talk with you about his hose kits.
              Regards, Kent
              Kent
              NCM Founder - Member #718
