1970 - Bracket - Trans. Mtg. - NCRS Discussion Boards
  • Stephen L.
    • August 29, 2007
    • 205
    hi all - on page K190 of the 1970 AIM, are the brackets that bolt "7" goes through welded to the crossmember? - or do they separate once unbolted from part "5" (bracket trans mtg)? - the reason i ask is i unbolted each...one came off the cross member - the other appears welded on - thanks!! - stephen
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 1970 - Bracket - Trans. Mtg.
    The brackets were welded to the crossmember when the frame was made, and are considered an integral part of the frame. It appears your frame requires a minor weld repair...It'll help if you have a wire feed MIG welder and know how to lay a nice bead.
    If the bracket had been assembled to the frame at the assembly plant, it would have a separate part number listed on this sheet, or another sheet detailing any frame assmembly...and there is none. If it was bolt-on part provided with the frame assembly, it would have been identified with a square symbol with a diagonal line through the square, and the lower half of the square colored...you'll see these symbols throughout the AIM for bolt-on parts provided with assemblies.
    • Stephen L.
      • August 29, 2007
      • 205
      many thanks Chuck!
        Stephen -
        It's also helpful to refer to Assembly Manual sheets by the UPC Group number and Sheet number at the bottom of the page instead of by the "page" number; there are several different reproduction versions of the manual, copied/printed by different vendors who applied their own "page" numbers, so they're different from one vendor's manual to another. Using the UPC Group number and Sheet number makes a common reference for finding the same page regardless which vendor supplied the manual.
        • Stephen L.
          • August 29, 2007
          • 205
          Didn't know John - thanks for the head's up and will do - in this case, UPC 6, sheet B4 - thx, stephen
