62 Steering Box/Column Shims - NCRS Discussion Boards
  • Terry D.
    • May 31, 1987
    • 2692
    Looking for advice and/or article on how to determine number or thickness of shims between steering box and frame. Also the shims at the top of the steering column. I know that if you took apart an original you would just keep track, but I'm dealing with a basket case here. Does the 1953 Chevy Service Manual cover this? The ST-12 just says to make sure they are replaced to their original position. They never expected Bubba to take it apart and loose the pieces.
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: 62 Steering Box/Column Shims
    Terry...
    There should be no need to add shims between the steering box and frame, unless the steering column is really out of line. after the box has been installed, Do not tighten the bolts, until the steering column bracket under the dash is mounted. The angel of the column will set it self some what...add shims as required to maintain this angle and straightness as you tighten the mounting bolts. I used {6} six shims on my 62 that is presently being restored. shims may be ordered and usally come in sets of (3) three.
    Note...be sure to slide the outer steering column plate on as you insert the column into the firewall. Also a good idea is to use new hard and soft seals.
    • Terry D.
      • May 31, 1987
      • 2692
      Dennis
      Thanks for the info. I got all new seals etc. The six shims you used, were they on the top column mount? And are you saying I shouldn't need any at the frame? If I do who has them? Can't find them in any of my vendor catalogs.
      • John T.
        NCRS Financial Officer
        • January 1, 1983
        • 292
        Corvette Central shows them as 242033. 4 for $4.15
        Hope this helps
        John
        • Terry D.
          • May 31, 1987
          • 2692
          John
          That looks like whats in the AM, but I"m still looking for the correct way to tell how many, if any, you need. Surely if there is suppose to be shims somebody knows how and why they were used.
          • Bruce B.
            • May 31, 1996
            • 2930
            Terry,
            After reading your initial posting I went out and replaced the steering box in my 62. Instead of following the instructions in the ST-12 I bolted the box (leaving the bolts finger tight)to the frame before doing the under dash bracket. After doing that I looked in the car and I could see where the top of the column was off to the left side of the desired position. I then installed the under dash brackets and went and checked out the steering box position. The bolts gave me an indication of where shims were needed, so I added just one 1/16 shim and everything seems ok. There were no shims installed by the last guy who removed the steering box, but by the looks of his work he probably did not know what shims were.
            Bruce B.
            • Terry D.
              • May 31, 1987
              • 2692
              Bruce
              Thanks for the info. What did you use for shims?
              • Bruce B.
                • May 31, 1996
                • 2930
                Terry,
                I used typical u shaped body shims, they come in 1/16" and 1/8" thickness.
                When and if I redo the car I will get the correct shims, although I don't know what they look like. I just looked in the Corvette Central catalog and they look the same.
                Bruce B.
                • Terry D.
                  • May 31, 1987
                  • 2692
                  Thanks Bruce. I looked in their catalog also, but it does not list them for a steering box shim, although they do look like what's in the AM. Thanks again
                  • Bruce B.
                    • May 31, 1996
                    • 2930
                    Terry,
                    In CC catalog 1F, on page 127 they list p.n. 242033 "Steering Box Shim 1/4".
                    Bruce B.
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Woops, thats 1/16" on the shims.
                      Bruce B
                      • Terry D.
                        • May 31, 1987
                        • 2692
                        Bruce
                        Thanks, I've looked at that page several times and missed them. A sure sign of old age creepin in
