1971 Axle Ratio and Numbers? - NCRS Discussion Boards
  • Greg F.
    • February 21, 2007
    • 253
    I have a 71 small block. I pulled the following numbers from the bottom of the rear:
    AW W 039 E 1
    I believe AW is 3:08 gear ratio. What is the rest of the number represent?
    I'm trying to get the correct information so I can purchase a reproduction window sticker. There are two options on the Triple A (window sticker) list for Axle Ratios and they are as follows:
    ZQ8 Economy Axle Ratio
    ZQ9 Performance Axle Ratio
    Would the 3:08 that I have be the ZQ8 option?
    Thank you,
    Greg
  • Warren F.
    • December 1, 1987
    • 1516
    Re: 1971 Axle Ratio and Numbers?
    Greg,
    W is Warren Gear & Axle plant, 039 is the 39th day of 1971, E is for Eaton plant, 1 is for 1st shift.
      • 43234
      Greg-----
      Assuming that the car is a 4 speed, then I would say that "ZQ8" would be the correct code. It's definitely not "ZQ9".
      • Greg F.
        • February 21, 2007
        • 253
        Thanks Warren and Joe!
        Joe - There is a 2:73 gear ratio that I was unaware of. Would that be the ZQ8 Economy Axle Ratio?
        Sorry to be a pest, but I know this is the best place to get the correct answer,
        thanks again,
        Greg
          The two distinctions were 3.08 (economy) and 3.36 (performance) for the base SB presuming it was equipped with a 4-spd, manual tranny. The lower numeric ratios were used with automatics.
            "E" signifies the manufacturer of the Posi unit (Eaton).
