Help ID master cylinder - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 384
    Delco assembly, casting number 5460346, 1-1/8" bore dia, deep-hole rear piston, front outlet port has 7/16-20 female thread; rear port has 9/16-18 female thread. Two bleeder screws. Machined boss on side adjacent front outlet stamped '2067'. Machined pad on nose stamped 'HK'.
    I thought this was correct for 72 Corvette w/pb. Can anyone confirm or otherwise ID? Thanks in advance.
    • 43237
    Re: Help ID master cylinder
    Jeff-----
    The date code indicates it was manufactured on the 67th day of 1972 (March 2, 1972). However, the "HK" code is not, as far as I know, a Corvette code. Are you sure it's not "MK"? "MK" was used for some 1972 Corvettes with J-50. If it's, for sure "HK", then I don't know what it's for. Keep in mind that the 5460346 casting was used for other non-Corvette master cylinders.
    • Jeff S.
      • July 31, 1984
      • 384
      Joe
      On closer look (magnified), I think the stamp is indeed "MK". Thanks.
