396/425 Block Coolant Drain Plugs...What Type??? - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2660
    Can someone tell me what type the factory correct coolant drain plugs found in the engine block on a 396/425 engine just above the oil pan rails are?
    Are they a recessed, square head, a recessed, hex head or a square, outward protruding plug? Same question for the plug found in the lower left front corner of the block, just above the oil pan rail.
    James West
    • 43237
    Re: 396/425 Block Coolant Drain Plugs...What Type?
    James-----
    The coolant drain plugs above the oil pan rails were 1/4" NPT with external hex head and they were steel. They were available until recently from GM under GM #3889330 but they are now discontinued. You should be able to find suitable replacements in a hardware or auto parts store. I prefer BRASS for these. When painted with the block, they look pretty much like the originals.
    The plug in the front of the block near the oil pan rail is a different story. This is the plug for the block's main oil gallery (Mark IV big blocks, EXCEPT ZL-1, have the main oil gallery just above the driver side oil pan rail). I THINK that this plug is an internal, square head 1/4-18 NPT plug. IF SO, I think that GM #144011 will do the trick. It's still available. Check the size first, though, to be sure it's 1/4-18 NPT.
    • Clem Z.
      • January 1, 2006
      • 9427
      all the front oil galley plug are 1/4" NTP but some blocks used 1/8" NTP plugs in the side of the block for the oil gallery and these were internal 3/16" square. i used 3/16" square lathe hardened tool steel bits to remove and install these plugs
