Seat Cushion tags - NCRS Discussion Boards
Seat Cushion tags
  • Roy B.
    • February 1, 1975
    • 7044
    Seat Cushion tags
    53 to 60? Used cloth tags. 61 to 63? Cardboard tags?? Later C2's metal tags?? All having part number and dates. Need in-put with more info needed???
  • Justin B.
    • March 1, 1996
    • 478
    Re: Seat Cushion tags
    My 58' had the cardboard style with date and other unknown info.
    • Larry C.
      • April 1, 1980
      • 279
      Roy,
      My 1962 #13078 (build date 6-22-62) has the following information on black cardboard tags:
      Driver's back: MSWBP 2 10 61 / J A2F-1114-C / (no part #)
      Driver's bottom: MSWBP 2 17 61 / J A2E-1113 / 3782958-6
      Pass back: MSWBP 2 10 61 / D A2F 1124-C / 3819176
      Pass bottom: MSWBP 2 17 61 / E A2F 1123-A /3782958-6
      These seats are original, still with the factory red upholstery. Note that both backs and both bottoms bear the same dates and would seem to be 1961 model frames, not to say that there was any difference. The driver's bottom tag has some previous water damage, is faded to white cardboard and the letter following 1113 is illegible.
      The slash marks between the numbers above indicate separate lines on the tags. I would post a photo but not sure how to do.
      • Roy B.
        • February 1, 1975
        • 7044
        Re: Seat Cushion tags Justin
        I know 53 to 57 had cloth may be begining in 58 "late"carboard then. Thanks
        • Gary C.
          Administrator
          • October 1, 1982
          • 17672
          Roy, my '57 original seats had cloth tags on the seat bottoms and cardboard tags on the seat backs. May have the order reversed. If I get a chance today, will check my files and post the part no.s Gary....
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Greg P.
            1961-62 Team Leader
            • March 1, 1985
            • 55
            Roy here are the tags from my may 5 57 build, black tag reading BP 7 30 56 ,M.S.&W.D.160-A, 3740251 I hope this helps
            • Justin B.
              • March 1, 1996
              • 478
              Actually the tags are dated late 1957 which would be correct for my November production #1327 58'. JB
              • Roy B.
                • February 1, 1975
                • 7044
                Re: Seat Cushion Gary that may be the change
                for a late 57
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Right now it's Gathering info time but who cares
                  ME! I like things some people care less about.
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17672
                    '57 Seat Cushion tags
                    Roy, my '57 VIN 300X had cloth tags on seat bottoms (water soiled beyond reading #'s) and oval elongated black cardboard tags with raised stamping on seat backs. Cardboard tag stamping per the following:
                    BP 7 30 56
                    M.S.&W.A. 160A
                    3740252
                    Part no. on the other tag is 3740251
                    Regards, Gary....
                    NCRS Texas Chapter
                    • Greg P.
                      1961-62 Team Leader
                      • March 1, 1985
                      • 55
                      Gary same numbers as mine *NM*
                      • Joe M.
                        • February 1, 2005
                        • 590
                        Re: Gary same numbers as mine
                        Jan built 57 seat tag - WHITE RECTANGLE CLOTH TAG AS SHOWN IN PREVIOUS POST
                        3740252
                        7.30.56
                        10.5
                        57 160 A
                        April built 61 - BLACK, THICK CARDBOARD AS SHOWN
                        MSWBP 8.5.60
                        C A1F-1124-L4
                        3782956-6
