Front Spring Rate 1961 RPO 687 - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    Anyone know what the spring rate and wire diameter should be for this option?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    This doesn't answer your question, but...
    ...I believe they were identical to regular production. DC
      • 43236
      Re: This doesn't answer your question, but...
      Dennis and Jerry-----
      I agree. RPO 687 for 1960-62 utilized the same springs as all other 1960-62 Corvettes. This spring had a rate of 1235 lbs. and a free height of 13-3/4". I don't know the wire diameter.
      1957-59 with RPO 684 did use a different spring. That spring had a rate of 1145 lbs. and a free height of 11-1/8"
      • Roy B.
        • February 1, 1975
        • 7044
        Re: Front Spring Rate 1961 RPO 687
        Original springs will have a flat area at the top and the part# in them.
        • Jerry G.
          • April 1, 1985
          • 1022
          Re: Starting to make sence
          I'm learning about the 61 cars. This one has the appropriate brake hardware but i expected to see the monster springs and sway bar. I was a little concerned for a while. it does have the 5 leaf rear spring with the longitudinal groves.
          • Mike E.
            • February 28, 1975
            • 5139
            Jerry--
            It shouldn't have 5-leaf rears. Should have 4-leaves, even for RPO687 usage. I'd guess that if you look carefully, one has been added. If not, check dates on the bottom leaf--it probably won't have a correct date for your 61.
