C-3 transmission stamp - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I just purchased a 69 coupe. The owner stated in writing that it was a numbers match drivetrain. The transmission is incorrect. The numbers are P-O2-11. There is no serial number on the case at all. Could somebody identify this Muncie 4-speed, and tell me what it is out of and what year? Thanks, Mark
    • 43236
    Re: C-3 transmission stamp
    Mark-----
    Those numbers don't provide enough info to ID it. If you could provide the CASTING numbers found on the main case (passenger side), extension housing, and side cover, we might be able to narrow it down.
    • Mark A.
      • February 1, 1996
      • 299
      Joe,
      Main case # is 3851325. Tail housing is 3846249. In the main case is a cast circle with a 12 in it. I could not see the one on the shift housing. Thanks, Mark
      • David D.
        • 330
        Mark, It is a 1965 trans, P0211 I believe is February 11th, 1965. With no VIN stamp, it was probably an over counter replacement trans. Dave
          • 43236
          Mark------
          I agree with Dave; it's a 1965 Muncie. Also, it was likely one of the last ones built with the 3846249 extension housing. That extension housing has the speedometer fitting on the driver side. Later Muncies, including 1969, had the fitting on the passenger side. So, someone must have done some other "adapting" (like, changing the routing of the speedo cable and, most likely, changing the cable) to make this transmission work in this car.
          While the 1965 Muncie will otherwise fit perfectly in a 1969, it's not as strong of a transmission as the 1966+ Muncies.
