1964 Frame Question - Coupe vs Roadster - NCRS Discussion Boards
  • Ed K
    Is there a physical difference in the frames of a 64 Coupe vs a 64 Roadster? Primarily is there a #2 body bracket on a 64 Coupe frame & it's just not used or is the #2 bracket only on a 64 Roadster frame?
    Thanks All
  • Joe C.
    • August 31, 1999
    • 4598
    Same Frame
    Frame same.
      • 43241
      Re: 1964 Frame Question - Coupe vs Roadster
      Ed-----
      The extra set of body mounts was used for the convertible only. However, it was added to the frame at St. Louis. So, the frames as-delivered to St. Louis were the same.
