C2 hood support - NCRS Discussion Boards
C2 hood support
  • Larry S.
    • March 11, 2007
    • 457
    C2 hood support
    The hood support mechanism on my '67 SB is acting up. It doesn't want to 'catch' to hold the hood open until I move the hood up and down several times, when it finally locks into place. Is there an easy fix that I'm missing? Thank you, and I hope everyone had a Merry Christmas!
    Re: C2 hood support
    Larry -
    Make sure the "pawl" is moving freely and is properly lubricated so it drops into place when the support is extended.
    • Larry S.
      • March 11, 2007
      • 457
      Re: C2 hood support
      John, I lubricated it as best I could; I squirted some engine oil around the pawl, but no improvement. The pawl os hard to get to. Should I use WD-40?
      • Tom D.
        • September 30, 1981
        • 2134
        Re: C2 hood support
        It's possible to slip the two halves apart, if you take it off the car and reverse the direction of a normal "pull apart".
        Then perhaps you can get a good look at the insides.
        Tom D.
        4889
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
