Muncie removal - NCRS Discussion Boards
Muncie removal
  • jim cear
    Muncie removal
    How much does a 63 Muncie weigh? And, on a totally subjective basis, scale of 1 -10, how difficult is removal and replacement using jack stands? Thanks
  • David B.
    • July 31, 2004
    • 330
    Re: Muncie removal
    Jim,
    Approximately 90 lbs.
    Not too hard to remove. A little harder to get back in.
    I would give it "4 wrenches" on the difficulty scale.
    Put the car up pretty high on the stands for best leverage to lift it down. (There isn't enough room for a transmission jack to be helpful in my opinion.)
    Tape a baggie over the tail case output shaft opening to avoid a lot of leakage, even if the case is drained first.
    Dave
    Dave, 1969 427, 1957
    Previous: 1968 427, 1973 454
    • Tom P.
      • April 1, 1980
      • 1815
      Re: Muncie removal
      They're only 75-77lbs-------------------on my bathroom scales!
      • David B.
        • July 31, 2004
        • 330
        Re: Muncie removal
        Tom,
        They seem to get heavier as I get older.
        Dave
