62 Starters 7233/7889 Here we go again...... - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Ok......Been thru archives, twice. Searching "starter" & 7889 then 7233. Never saw the definitive answer to the difference in the Spec Guide vs JG on the 62 starter thing.
    JG says ALL manual 62's use the #7233.
    Spec Guide says early manual 62's use the 60/61 type #7889.
    Confusing........Is there an answer to this or is it still a mystery?
    I have a Sep 6, 61 built 62, #483, Eng assy Aug 28,61. Will a June 30,1961 #7889 fit into the date range for my engine, or do I need the unobtanium early dated #7233? I'm not really interested in any restamps.
    Rich
  • David K.
    • February 1, 1976
    • 592
    Re: 62 Starters 7233/7889 Here we go again......
    Rich, just went out and looked at the started on #399. It has a 1107233 with a build date of H 11.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Hi Dave, Thanks for getting under for a look. So it looks like I need the 7233 for mine, built a bit later than yours. The chances of finding one are certainly slim.
      Rich
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Rich, I'd guess your best bet is...
        ...Pirkle's wait list if it is still active. Certainly worth a try, along with an ad in The Driveline. Over the years, I've acquired 3 - 233's from him with working dates & no restamps from John. Best in the business. DC
        • Dennis C.
          • January 1, 1984
          • 2409
          Oh, BTW - Hope you've already got a VR... *NM*
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            Re: Oh, BTW - Hope you've already got a VR...
            Nope, need a regulator too. Thanks for reminding me......ha,ha...ha,ha...
            Since it's going to take me about a year to get to the point of needing this stuff, I best get myself on John's waiting list. Let's see, a rare 723 starter, a 9002E VR(preferably one that works, as well as being pretty!), a 2174 generator(already have that, came on the car but it's a rebie), some dated wire, a correct battery to energize all this stuff, along with some dated gas and oil when it comes time to fire up the engine.:-)
            Rich
            • Mike E.
              • February 28, 1975
              • 5138
              Re: 62 #311 had a 7233
              The 7889 vs 7233 starter debate has been around for one long period of time. That's one of those that showed up, as I recall, early in the process of developing the JG for 61-62. The AIM, section 6, sheet 11.00 was drawn on 5-3-61 and indicates 1107233 as the starter number, and indicates no engineering changes. HOWEVER, National Service Data for 1962 indicates that all 283 and Corvette used 1107889, and 327 and 409 used 1107233. That, as we know, is quite incorrect, but may have been used somewhere along the line to cause doubt to creep in.
              Original owner. Reasonably correct date (certainly appropriately precedes assembly date). Could it have been installed on the car at the factory? Yes.
              Should it have been? Not according to the AIM and observation of many 100's of original 62's. A single anomaly--not likely. Part of a day when they ran out of 7233's or found a few left over 7889's? Possible.
              By the way--I've had about 15 real 7233's over the past 32 years of collecting--they used two different styles of "3's" in the stamping.
