A quickie question - NCRS Discussion Boards
A quickie question
  • Chuck R.
    • April 30, 1999
    • 1434
    A quickie question
    I'm purusing the vendor rags for the rubber supply and vapor return lines up at the pump and filter.
    What sizes are these lines respectively supply = ??? Vapor = ???
    I know it's a tough one, but someone has to challenge you folks every now and then.....
    Chuck
    Re: A quickie question
    I'd forget about what size the rubber was and look for catalogs that have 'correct' S-shaped hoses to service the fuel pump. These were specially formed to thwart the potential for the lines collapsing under fuel flow surges....
    • Chuck R.
      • April 30, 1999
      • 1434
      I had a chance to look over my steel lines when I got home last night and it appears that the supply line is 3/8" and the vapor return is 1/4" Or do I have them turned around?
      The filter assembly is M.I.A. so I'll assume that there is a 1/4" line from the filter to the steel return line......according to the pictures anyway
      The books aren't very clear, especially since they don't make an exact replacement filter any longer. I guess it's a configuration thing that makes the non-O.E.M. replacements different.
