Need pic of part for 69 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    AIM manual UPC C60 sheet C5 part # 3940921. This is the solenoid stop extension that bolts to the carb lever.
    I am not having luck finding this part and if I could see a real one in a picture I may resort to having it made.
    I searched the archive to no avail.
    I would appreciate any info on this.
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Salvatore I.
    • April 1, 2004
    • 114
    Re: Need pic of part for 69
    Try Dr. Rebuild....in their catalog, search under the letter "s"...there are carb solenoids, etc for 68+ model years....
    www.docrebuild.com
    • Ralph A.
      • May 31, 2002
      • 236
      Thanks Sal, but this is a 69. For 70 the solenoid is different and mounts differently and the stop is part of the lever. He shows the solenoid, DISC, which I have and the bracket. Just need the stop extension.
      Thanks for you suggestion.
      Ralph
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
      • Dick W.
        • 10483
        Ralph, what engine??
        Dick Whittington
        • Ralph A.
          • May 31, 2002
          • 236
          1969 350/300 A/C Auto
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
          • Dick W.
            • 10483
            Ralph, I do not have a picture, but I believe that several GM car lines used this bracket and solenoid. I would look at Cadillac, Olds, and Buick of this vintage. You may be able to find a bracket and/or solenoid
            Dick Whittington
            • Ralph A.
              • May 31, 2002
              • 236
              I have the solenoid and bracket. Just need the lever extension or a good picture of one to make it. Part # 3940921
              Ralph Adams
              NCRS: 38137 LA: 112
              Slidell, LA 70461
              • Jeffrey S.
                • May 31, 1988
                • 1888
                Ralph:
                If you are talking about a solonoid that attaches to the carb I don't believe that the '69 350/300 A/C auto had any solonoid at all. My very original '69 doesn't and never did. Even if the JG says it did, I belive it is wrong.
                Jeff
                • Ralph A.
                  • May 31, 2002
                  • 236
                  That would make sense as the AIM calls for it on RPO L36, L46 with M20 or M21. The sheet also removes the M40 option. From that you may assume the base engine with C60 did not have one. This car is a very late 69 (12/1/69) and all the AIM mods referenced should have been in place during its build. Have you had points deducted for lack of solenoid?
                  I may not add and have discussion at time of judging.
                  Thanks for this info.
                  Ralph Adams
                  NCRS: 38137 LA: 112
                  Slidell, LA 70461
                  • Jeffrey S.
                    • May 31, 1988
                    • 1888
                    Ralph:
                    No points deducted. I have a second edition judging guide (not the newest edition) and on page 81 it states: "Early 1969 air conditioned cars may not have this solonoid and bracket." My car is an Oct. '68. I don't know if this is further clarified in the 3rd edition. Perhaps late cars had them. I can't say for sure and I'm sure that others who are more knowledgable will chime in.
                    Jeff
                    • Dick W.
                      • 10483
                      Question Ralph, does the wiring harness have the wire for the solenoid?? If not it would be a good guess that it was never equipped with it.
                      Dick Whittington
                      • Ralph A.
                        • May 31, 2002
                        • 236
                        No wire exist currently, but this harness is not original.
                        Ralph Adams
                        NCRS: 38137 LA: 112
                        Slidell, LA 70461
