C2 More 63 pics, eng stamp, trans, orig rad??? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11320
    Found some more info about our 63. Car continues to have some hidden treasures.....
    I got the Powerglide date(thanks Todd!). It's T02 15D, Tonowanda Feb 15 day shift, about 12 days before the car assy and 3 days prior to engine assy. When were the engines and transmissions usually assembled together? Was it a separate assembly area or was the trans attached at the same place as the engine was assembled? Just curious if anyone knows.
    Also, discovered the radiator numbers under what appears as original paint. Took a tracing and I see 63 A(Jan 63). I read somewhere that the center top mount bracket was 1" wide on 63/64 originals, and 2" on 65up. This one is about 1 1/2" so I'm confused. Ordered my new C2 books from the store but not in yet. I am really thinking this could not be the original radiator. 44 years? Unlikely even if the car only has 67000 miles on it. Maybe a restoration rad stamped up with the right stuff? Is there some telltale difference I could see?
    Close ups of the engine stamp pad too. I see on both the cast date and the assy stamp traces of yellow paint. Anyone seen that before? The cast date is not very nice. You can barely make it out but it's B123. It took me quite some time before purchase to verify it. It's definitely cast iron, unfortunately it must've had some crud in the mold when they cast it, leaving it pretty difficult to read.
    Also I'm thinking the carpeting isn't original, but just very faded replacement. What does the original carpet backing?
    More pics....
    Rich
  • Wayne M.
    • March 1, 1980
    • 6414
    Rad top cushion boss 2" for '63-64; 1" after
    Can't explain why yours is less than 2".
    • Wayne M.
      • March 1, 1980
      • 6414
        Re: C2 More 63 pics, eng stamp, trans, orig rad???
        Rich -
        Nice car! The "TO" on the trans pan ID is for Toledo, not Tonawanda; the engine and transmission were joined at St. Louis.
          Rich -
          • Kevin M.
            • November 1, 2000
            • 1271
            One of the best looking pads I've seen great example of broach marks.
            Kevin
            • Kevin M.
              • November 1, 2000
              • 1271
              Kevin
              • Mike M.
                • May 31, 1974
                • 8377
                perfect pad data and broach marks. ya got a winner there. mike
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11320
                  Re: Rad top cushion boss 2" for '63-64; 1" after
                  Wayne, Thanks for the great photos to compare.
                  So I must've measured the rubber cushion, it's 1 1/2". I took the bracket off and it looks like it's actually 1"(pic below).
                  Cleaned the rad part# area and took some more pics & close-ups of the digit "3" in the part# & in the date. Sure seem like they're consistent.???
                  I'm not sure what this one is as there's no explanation why it's marked 63A. Repro?, but I don't understand why a repro shop would go to all the trouble and not make the mount bracket 2",
                  Thanks John. Yep got my T's mixed up....Powerglide=Toledo.
                  Yes after I took the close-ups of the engine pad it really shows the broach marks clearly. I was happily impressed.
                  Thanks for the guidance....
                  Rich
