RE-STAMPING carburetor core - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
  • mike cobine
    Re: RE-STAMPING carburetor core
    Considering that within a given year, most carbs only differ in the jets and the metering rods, the idea of a couple thousand dollars because the carb has the right numbers is a bit on the insane side.
    That is why I will find it easy to build a very common carb with the same jets and rods and set my 390 hp Q-Jet on the shelf to prevent further deterioration of the pot metal. I don't have to have a numbers carb to run, and should I ever judge, I'll have my numbers carb to use.
    • mike cobine
      • Mark #28455
        Another way to do it
        There are several companies (like Eastwood) that sell a low temperature rod for repairing pot metal castings. After cleaning off the chromate coating, you can carefully fill in the old numbers, then carefully sand/file it smooth, then when you zinc plate the casting prior to re-chromating, just leave that area in the bath a little longer and you get that slightly rough (instead of machined) surface texture.
        I have never done this myself and do not advocate selling bogus carbs as real, but the reality of it is that as certain collectors drive up the $$$ value of rare parts to astronomical levels, someone steps in to fill the demand - simple economics! Just like the epidemic of restamped blocks, the era of restamped carbs is here now. BUYER BEWARE!
        Mark
        • Mark #28455
          Mark
          • Lyndon S.
            • April 30, 1988
            • 1027
            Re: Another way to do it
            Amen, brother!
            • Lyndon S.
              • April 30, 1988
              • 1027
              Amen, brother!
