How to determining the ratio of a rear end?? - NCRS Discussion Boards
  • Daniel S.
    • February 1, 2000
    • 164
    Re: How to determining the ratio of a rear end??
    You can try this link.
    http://www.idavette.net/tech/ratioc.htm
    • Daniel S.
      • February 1, 2000
      • 164
      • Jim K.
        • August 31, 2000
        • 554
        #18
        The only thing I can add here is to turn the input shaft 10 full times and count the side revs, then do what Duke and the others said with the 2X oe 1/2X but then factor back in the 10. this should get you closer to the 355 or 370 mark... just my $0.02
        Jim
        • Jim K.
          • August 31, 2000
          • 554
          #19
          Jim
          • mike cobine
            #20
            I think Tom was looking for this URL.
            The only problem is that the speed difference between a 3.55 and 3.70 is small. With a 27 inch tire, 3000 rpm will give 65 mph with a 3.70 and 68 mph with a 3.55 gear. Unless your speedometer is very accurate, you may not know which gear you have from doing the tach and speedometer comparisons. And you need to know the rolling diameter of the tire which varies from manufacturer to manufacturer on a given size.
            The best way was already suggested in turning the driveshaft 10 times and then calculating. It is a lot easier to check 18 turns than 1.8 turns.
            • mike cobine
              #21
              • Tom S.
                • March 1, 2004
                • 1087
                #22
                Mike long time no hear.. Yes that ws the site I was looking for. Thanks Mike!
                • mike cobine
                  #23
                  With all the things that happened in the last year, I have been scattered across several sites and a lot more in the lurking mode than the typing mode.
                  • Tom S.
                    • March 1, 2004
                    • 1087
                    #24
                    Mike it is good to have you back !I have always found you to be very helpful!Thanks again for all your help! Tom
