C-2 fuel gauge sender - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    I looked in the archives and did not find this. How is the black fuel strainer on the bottom of a 67 C-2 pick up pipe removed? It has a split in it. Thank you in advance. Dale
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: C-2 fuel gauge sender
    Dale,
    I changed one on my 63 some time age and remember just twisting it off and reverse for installation of the new strainer.
    • Timothy B.
      • April 30, 1983
      • 5186
      Dale,
      • Donald T.
        • September 30, 2002
        • 1319
        Dale,
        It is just a friction fit. The old one may be a little difficult to pull off, so you may need to use some penetrant.
        • Donald T.
          • 1319
          Dale,
          • Dale S.
            • November 12, 2007
            • 1224
            Thank you all, I will put some "good ole" MALTBY penetrating oil on it. It is so good you can spray some on the ground, stand on it and in 3 minutes you can taste it. Dale
            • Dale S.
              • November 12, 2007
              • 1224
