Rear End Pain - NCRS Discussion Boards
Rear End Pain
  • Noel K.
    • November 1, 2004
    • 84
    Rear End Pain
    No, this isn't a middle age hemorroid problem for me personally. But (no pun intended ) after having my 65 small block less than road friendly with it's 4:11 rear end, I've decided this winter's project should be to put in a more user friendly road gear - probably a 3.55 - which I know has been discussed before.
    However, thinking that I want to purchase a complete new or rebuilt third member, not just change out the ring/pinion I would like to request suggestions to start my search for the new rear end. I checked the Driveline and found an advertisement for a company in Florida that will rebuild my existing rear end - but I believe, at least in the beginning of my research, that I'd like to purchase a complete new unit. I don't believe the existing rear end is "matching numbers" and purchase of the entire unit is not numbers critical - especially since this is a non-judged item.
    Thoughts - suggestions ?
    Thanks in advance.
    Noel Kendall
  • Larry S.
    • September 19, 2007
    • 204
    Re: Rear End Pain
    Try Bairs in Linesville PA.
    1 800 421 9644.
    They are top-notch in the gear area.
    • Larry S.
      • 204
      Re: Rear End Pain
      1 800 421 9644.
        • 43221
        Re: Rear End Pain
        Noel------
        No such thing as a complete NEW differential carrier unit anymore. They've been discontinued for years. Most of the components to build one up from all new pieces are long-gone, too. The best you can do is to buy a rebuilt unit and pay the core charge. By the time it's all said and done, you'll be talking about a grand and more if you want a new aftermarket ring and pinion gears installed in the unit.
          • 43221
          Re: Rear End Pain
          Noel------
          • Erich C.
            • January 31, 2007
            • 137
            Re: Rear End Pain
            Another option would be to install a 5 speed Overdrive trans. Do a search for 5 speeds, there are several companies offering kits using the Tremec trans. O.D. ratios available are .64/.68/.82 . These kits are supposed to be bolt-ins with no mods. to the car. Probably more $$$ than just doing the rear but you would keep the accel. of the 4.10 and still be able to cruise comfortably on the highway.
            • Erich C.
              • January 31, 2007
              • 137
              Re: Rear End Pain
              • Mike M.
                • September 30, 1999
                • 710
                Re: Rear End Pain
                Noel, I'm just wondering why you want to change your gear ratio. I have 4:10 and I like them. I don't do much highway driving, but it wouldn't stop me. Mike
                • Mike M.
                  • 710
                  Re: Rear End Pain
                  • Mike M.
                    • May 31, 1974
                    • 8389
                    Re: Rear End Pain
                    agree with mike. i routinely drive our 57 vette with 4.56:1 couple hundred miles one way. little hard on fuel but as long as the engine is healthy, 4000 to 5000 RPM won't hurt a sbc within specs. hate leaving the line with anything under 4.11 to 1.mike
                    • Mike M.
                      • May 31, 1974
                      • 8389
                      Re: Rear End Pain
                      • john daly
                        Re: Rear End Pain
                        If you have an M20 trans I would suggest you consider a 3:36 ratio. I have that in my 67 sb and it seems like a perfect all around combo....no drag racing though.
                        john
                        • john daly
                          Re: Rear End Pain
                          john
                          • Noel K.
                            • November 1, 2004
                            • 84
                            Re: Rear End Pain
                            Currently with the 4:11 I'm running about 3600 rpm at 65 mph so the 6500 tach redline for the 365HP is not excessive. I do get some shifter vibration as the tach goes higher. The car tracs and drives straight ( has had a frame off about 4 years ago) and I've wondered if there is a balance problem in the drive shaft. I've had the front end aligned and tire balanced. I had to have the engine rebuilt last year and the flywheel was balanced at the time.
                            The vibration is annoying and not evident at lower rpm - that's one reason. Secondly I would like to get a little better gas mileage for the trips I do take, although I'm not sure I want to put $1,000 into the project. No more miles than I drive the car a year, it will take a long time for an increase in gas mileage to add up to the rear end exchange cost.
                            Any thoughts on the driveline/shifter vibration - causes and/or cures ?
                            Again, thanks in advance.
                            Best to all this holiday season
                            Noel Kendall
                            • Noel K.
                              • November 1, 2004
                              • 84
                              Re: Rear End Pain
                              Noel Kendall
