66 - Front Block Oil Passage Bolt/Plug - NCRS Discussion Boards
  • Eddie H.
    • September 30, 1999
    • 36
    Does anyone know the part number for this bolt/plug and the availability?
    This bolt/plug goes in the front of the block.
  • Mike M.
    • May 31, 1974
    • 8377
    Re: 66 - Front Block Oil Passage Bolt/Plug
    should be able to get a handful at the local junkyard . they're on flint cast sbc from 55 thru at least 67(when i loose interest). mike
    • William C.
      • May 31, 1975
      • 6037
      There are several passages in the front of the block, the threaded one toward the top is a standard pipe plug. If you are referring to the ones at the cam gallarys, they are "welch Plug" style are are available from most NAPA or similar stores. I assume this is a smallblock? If a bigblock, there are pipe plugs in main gallarys relativelly low on the front of the block, these will dump a quart of oil on the ground in a couple of seconds at startup if not installed. Don't ask me how I know this...
      Bill Clupper #618
      • Ray G.
        • May 31, 1986
        • 1189
        Re: Chuckled when reading your answer Bill Clupper
        Hello;
        Did a similar "oil the floor" thing a few years ago.
        Laughing is good.
        Forgeting oil plugs bad.
        Always enjoy reading postings on here.
        Ray
        I hope you dance
