C1 Block Numbers by roaddraft tube - NCRS Discussion Boards
  • Susan Osborne
    #31
    (Message Deleted by Poster)
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12777
      #32
      Re: C1 Pictures
      You would expect them to have sharp poiters.
      PS to publish pictures you need to go tho the specific picture and the right-click it and select properties. then copy & page the address (ULR) into the picture edit field of this forum...
      greetings,
      Rob.
      Rob.
      NCRS Software Developer
      • Susan Osborne
        #33
        Re: C1 Pictures birth date
        Hi here is the born on date on the block. There is also a picture of the interior and the guages. I have more pictures if needed. Thanks again. Susan
        • Roy B.
          • February 1, 1975
          • 7044
          #34
          Optional Image URL:
          If you'd like to have the option of deleting your post later,
          please provide a password (CASE SENSITIVE!):
          As seen above You need to have a host for your pic's then copy it and then past it in to the (optional image URL) BUT first delete the http:/ that's in the white area then past your pic. sfter click on preview message to see if it worked
