427/390 vibration - NCRS Discussion Boards
427/390 vibration
  • James A. Lloyd Jr.
    427/390 vibration
    at 3000-3300 rpms i'm recieveing a hard vibration. it's hard to tell were it is coming from, it feels thru steering wheel floor board and drive train
    fyi ....recent work done on car......
    8 mths ago new center force clutch,rebuilt trans (3 pilot bearings, 2 throw out bearings since clutch put in, 1st piolot beadring had roller bearings, came apart, the last two were solid. the 2nd started whinning when clutch pedal pressed mecahnic said grease broke down??? 3rd put in two days ago)
    all new steering
    new alum. radiator and fan clutch( now runs 175-180 before 210-230)
    new headers , noticed some vibration when they were installed 2 mths. ago. seems to be worse since i picked it up 2 days ago from pilot bearing install
    wheels and bearings check out ok
  • D S.
    • March 1, 2005
    • 1551
    Re: 427/390 vibration
    Checked the rear transmission mount to see if it's not broken loose from the rubber pad? Engine mounts?
    • D S.
      • March 1, 2005
      • 1551
        All the pilot bushing/bearing replacements would indicate that the bellhousing isn't centered within spec to the crank centerline, and the throwout bearing replacements indicate incorrect clutch adjustment (inadequate pedal free play, which will fry the throwout bearing).
        Is the vibration engine rpm-sensitive, or car speed sensitive?
          • Albert P.
            • April 1, 2006
            • 205
            For what it's worth, I have a SB but had a vibration in the same range; turned out to be fan clutch.
            • Albert P.
              • April 1, 2006
              • 205
              • Albert P.
                • April 1, 2006
                • 205
                Disconnect belts and run engine to rpm to see if that eliminates the problem
                • Albert P.
                  • April 1, 2006
                  • 205
                    rpm sensitive
                      rpm sensitive
                        all mounts are ok
                          all mounts are ok
                          • Dick W.
                            • 10483
                            You mentioned that you noticed some vibration after the headers were installed. I would check for pipes or headers hitting the frame.
                            Dick Whittington
                            • Dick W.
                              • 10483
                              Dick Whittington
