1957 headlight switch - NCRS Discussion Boards
  • Mike N.
    • April 1, 2001
    • 110
    Can anyone give me a sketch of how the switch is suppose to be wired.
    The diagram I have from Lectric/Limited does not exactly match my switch.
    Picture of my switch wired is attached.
    What am I doing wrong??
    Mike
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11318
    Re: 1957 headlight switch
    Hi Mike, I'm not a 57 expert but I'll try.......
    Just looking at my ST12 55-57 diagram it looks like all's ok except for 2 black wires. Diagram shows 2 blacks. You must have another somewhere in the nest.
    One black should go to upper right terminal of your photo(empty?). This black is a 20g(small diameter), which goes to chassis gnd somewhere. Diagram looks like a gnd tiepoint somewhere, maybe to eng gnds or somewhere under dash at a gnd bolt?
    The other black(appears to go to tail light gnds), should go to the third from the right top row terminal(now empty in pic). It's a 18g(bigger diam black).
    Wow these diagrams in the book are hard to read. The mechanics back then must've needed magnifying glasses to see anything!:-)
    Hope it helps,
    Rich
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11318
      Hope it helps,
      Rich
        Mike -
        Here's a sketch I made 12 years ago during disassembly when I restored my '57.
          Mike -
          • Mike N.
            • April 1, 2001
            • 110
            I want to thank all of you who have responded to my request.
            FYI- I also found the info on Nolan Adams Restoration book.
            I still can't get my parking and headlights to work but I'm hoping it is my switch that is faulty. I will soon find out when the replacement arrives.
            Thanks again,
            Mike
