65 Seatbelt paddle - NCRS Discussion Boards
65 Seatbelt paddle
  • Jim V.
    • November 1, 1991
    • 587
    65 Seatbelt paddle
    I am restoring my 65 buckles and as always could some sage advice/help.
    I will be refinishing the paddles (bottom view pictured below) and I am considering using aluminum cleaner and alumi-prep prior to SEM Trim black. Are the paddles aluminum or some other alloy and would that matter? Finishing option two would be SEM self-etch and SEM trim black. Lastly on finish, is the finish a tad splattered from the factory or is that a result of the 40 year aging process?
    Is there a trick to removing the wedge from the pivot pin? I was successful with one buckle but the other is giving me fits..
    JimV
  • Mike G.
    • January 1, 1991
    • 418
    Re: 65 Seatbelt paddle
    Jim:
    You should be able to get a pick on the inside end of the wedge (in the notch) and push it out a bit. Then I've usually just wiggled it out with small needlenose pliers. Maybe a shot of penetrating oil would help.
    Is the alloy aluminum? Not sure, but a light coat of self-etch is what I would use.
    That spatter texture is factory original. Irving Air Chute used a kind of rubberized paint on these buckles. If you've ever tried to bead-blast one, you know what I'm talking about.
    I've never found a way to reproduce this surface texture with any success. If anyone out there has --pls share!
    • Mike G.
      • January 1, 1991
      • 418
      Jim:
      • Jim V.
        • November 1, 1991
        • 587
        Thanks Mike!
        Getting a pick on the inside end...hmmmm...it appears that inside end of the wedge is somewhat blocked by the return spring. Do I follow you?
        I was going to try some bristle brush splatter for the buckles...load the brush and then attempt to hand-catapult some fine splatter.
        • Jim V.
          • November 1, 1991
          • 587
          Thanks Mike!
          • Mike G.
            • January 1, 1991
            • 418
            Jim:
            First remove the c-clip off the shaft. Next put a drift on the wedge end of the shaft and tap it in. It will move about a quarter inch or so. That will expose the inner tip of the wedge and bottom of the slot. Gives you enough room to use a sharp pick and push wedge outwards.
            • Mike G.
              • January 1, 1991
              • 418
              Jim:
              • Eugene B.
                • May 31, 1988
                • 710
                Jim,
                There was a great article in the Fall, 1996 issue of the Restorer Magazine titled 1965-66 Seat Belt Buckle Restoration. It explains how to disassemble and reassemble the buckles.
                Good luck,
                Gene
                • Eugene B.
                  • May 31, 1988
                  • 710
                  Jim,
                  Good luck,
                  Gene
                  • Jim V.
                    • November 1, 1991
                    • 587
                    Got it....thanks Mike...NM *NM*
                    • Jim V.
                      • November 1, 1991
                      • 587
                      • Jim V.
                        • November 1, 1991
                        • 587
                        Gene...thanks..... N/M *NM*
                        • Jim V.
                          • November 1, 1991
                          • 587
