Stock speakers - NCRS Discussion Boards
Stock speakers
  • Michael G.
    • March 2, 2008
    • 485
    Stock speakers
    I'm trying to locate replacement original 4x6 (10 ohm) in-dash speakers for my 71'. Having no luck with any of the better known part suppliers. I dont want to damage the original am/fm stereo radio. If the proper replacements are a lost cause, is there something else that can be used safely with the original radio?
    Mike
    • 43240
    Re: Stock speakers
    Mike-----
    No problem. Order GM #16157512. This is a 4 X 6, 10 OHM speaker that's a direct replacement for your originals. These things list for about 47 bucks each. However, you should be able to get them for a LOT less through Delco dealers.
    These are NOT going to be up to contemporary high quality, "super-duper" stereo speakers. However, they will be as good or better than the original speakers were when they were new.
    You can also have your original speakers re-coned (assuming you have them), but I really think these new ones are the way to go.
      • 43240
      Re: Stock speakers
      Mike-----
      • Jim S.
        • March 1, 1986
        • 1405
        Re: Stock speakers
        Joe ,
        Would these also work on a 66 ?
        Jim
        • Jim S.
          • March 1, 1986
          • 1405
          Re: Stock speakers
          Joe ,
          Jim
          • Verle R.
            • March 1, 1989
            • 1163
            Re: Stock speakers
            Michael,
            I had a local shop in Tulsa rebuild my 65 speakers and they work like new.
            Speakerworks
            4732 S Mingo Rd
            Tulsa, Ok
            918-664-6299
            He was reasonable, about $50.00, and about one week turnaround. You would have to add shipping.
            Verle
            • Verle R.
              • March 1, 1989
              • 1163
              Re: Stock speakers
              Michael,
              Speakerworks
              4732 S Mingo Rd
              Tulsa, Ok
              918-664-6299
              Verle
                • 43240
                Re: Stock speakers
                Jim-----
                Unfortunately, no. The 1963-67 speakers have an attached "transformer" that I understand is necessary for compatibility with the 1963-67 radio units. These speakers don't have that device.
                  • 43240
                  Re: Stock speakers
                  Jim-----
                  • Jim S.
                    • March 1, 1986
                    • 1405
                    Re: Stock speakers
                    Joe,
                    Thats a bummer , because I don't have my original speaker. I can only hope the ones CC offer have the proper transformer ,and don't ruin my newly rebuilt radio.
                    Thanks for the responce,
                    Jim
                    • Jim S.
                      • March 1, 1986
                      • 1405
                      Re: Stock speakers
                      Joe,
                      Jim
                        • 43240
                        Re: Stock speakers
                        Jim-----
                        I think that the correct speakers for 63-67 are reproduced.
                          • 43240
                          Re: Stock speakers
                          Jim-----
                            • 11652
                            Re: Stock speakers
                            Note that the wiring connector will most likely differ from the original on the 71. You can modify it to make it work. That's what I did until I "get around" to having a batch reconed. I left the original factory wiring harness unmodified.
                            FYI, I'm quite sure this speaker is sold for a very good price thru most of the Corvete parts vendors. $18.95 at Corvette Central right now.
                            Patrick
                              • 11652
                              Re: Stock speakers
                              Patrick
