69 Thermostat housing question - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Would someone be able to post a pic of an original production 3877660 69 thermostat housing for me please?
    I discovered that mine is wrong due to the p/n number being on the flange so I'm looking for a correct one with the p/n on the neck. I understand that the production ones versus service ones have thin or thick numbers but don't know which is which so if I could see what a production one looks like I'll know if I should go for the thin or the thick numbers.
    Greg Linton
    #45455
    • 43221
    Re: 69 Thermostat housing question
    Greg-----
    A guaranteed original 1969 GM #3877660 thermostat housing. I'm not saying this is the absolute only configuration in every single nuance of detail used for every single 1969. However, this was the configuration used on at least one 1969.
      • 43221
      Greg-----
        • 43221
        And another:
          • 43221
          And another:
          • Harmon C.
            • August 31, 1994
            • 3228
            Greg
            Joe's pictures should help you find what you need. Be aware of the small hole and flange extension in the picture as some housings will not have this.
            Their are many small changes in this part number so I would have the picture in hand when looking for one.
            Lyle
            Lyle
            • Harmon C.
              • August 31, 1994
              • 3228
              Greg
              Lyle
              Lyle
              • Gerard F.
                • June 30, 2004
                • 3806
                Lyle/Joe,
                In what application was the flange extension and hole used?
                Just curious,
                Jerry Fuccillo
                #42179
                Jerry Fuccillo
                • Gerard F.
                  • June 30, 2004
                  • 3806
                  Lyle/Joe,
                  Just curious,
                  Jerry Fuccillo
                  #42179
                  Jerry Fuccillo
                  • Greg L.
                    • March 1, 2006
                    • 2291
                    Great pics, thanks Joe.
                    • Greg L.
                      • March 1, 2006
                      • 2291
                        • 43221
                        Jerry------
                        I'm not sure which applications used the extension and hole. I think that Chevy II might have been one of them. It was used for the accelerator pull-back spring anchor point, though. It was never used for any Corvette application. In fact, there was another PRODUCTION-only housing of a different part number that was used on some Corvettes in the early 70's that did not have the extension and hole.
                          • 43221
                          Jerry------
                          • Dale S.
                            • November 12, 2007
                            • 1224
                            Greg, Mine looks like Joe's second one except it has "1A" under the nunber where as Joes looks like "1C" under the part number. Dale
                            • Dale S.
                              • November 12, 2007
                              • 1224
