C3 fuel pump - NCRS Discussion Boards
C3 fuel pump
  • Jeff W.
    • November 1, 2005
    • 272
    C3 fuel pump
    Can a AC#41217 work in place of a #40769 on a 72 base 350?
    Jeff
    • 43236
    Re: C3 fuel pump
    Jeff-----
    An AC 41217 was originally used on some early 70's Chevelles with small block as well as some mid 70's Chevrolet pick-up trucks with small block.
    It should be a long canister pump with nipples on the bottom for fuel inlet and vapor return + a threaded fitting for fuel outlet.
    From a FUNCTIONAL perspective, it will work for a 1972 Corvette with base 350. However, the fuel nipples and outlet will be oriented incorrectly for the application. You will have to fabricate a fuel line from the pump to the carb and you may have difficulty getting a proper fit for the rubber fuel lines.
    Quite frankly, I would not recommend using it. Purchasing a correct fuel pump just isn't all that expensive and they are available. One word of caution in the latter regard, though: the AC 40769 fuel pump is discontinued and replaced by the AC 41240. The 41240 has a somewhat shorter canister than the 40769. This might, itself, cause a problem with fuel outlet line fitment. So, you might want to see if you can get a 40769, either NOS, or a 40769 clone from another manufacturer.
      • 43236
      Re: C3 fuel pump
      Jeff-----
