Manometer Inquiry..327-375 H.P. F.I.. - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    I have a 1964 327-375HP F.I. roadster and would like to know if I can buy a good used (or new, I suppose) manometer to set the injection up. I had it set up by a retired GM mechanic that had a manometer, but he did not want to sell it.
    This was about 4 years ago, and sooner or later I will probably want to set it up again(the previous mech. has moved and I can not locate him).
    If anyone has some ideas, please advise.
  • Ralph Harvey
    Re: Manometer Inquiry..327-375 H.P. F.I..
    Larry
    What pressure measurements do you want to check?
    R Harvey #28843
    • Ralph Harvey
      Larry
      R Harvey #28843
      • Larry S.
        • 204
        I think that a manometer checks fuel and vacuum pressure so that you can get a proper balance, but I am not totally sure how it works as it has been some time since I had my engine setup using a manometer. It does connect in-line with one of the injector nozzles and also the vacuum, but not sure of where you pick up the vacuum pressure?
        • Larry S.
          • 204
          • Chuck S.
            • June 30, 1991
            • 184
            The correct manometer shows up on eBay from time to time. I have also seen them advertised in the Driveline.
            • Chuck S.
              • June 30, 1991
              • 184
              • Talmadge W.
                • March 1, 1993
                • 17
                Larry, If you can "get out of the box" I could propose a method that has 20 times the resolution of the mercury manometer. It is a straight forward method of measuring the fuel pressure and the parts required should cost less that $50. I have used it on more than a dozen units with sucess. talmadge
                • Talmadge W.
                  • March 1, 1993
                  • 17
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17675
                    Am interested in your technique - appreciate if you post it. Gary....
                    NCRS Texas Chapter
                    https://www.ncrstexas.org/
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17675
                      NCRS Texas Chapter
                      • Verle R.
                        • March 1, 1989
                        • 1163
                        I would like to see a write up on you method also.
                        Thank you,
                        Verle
                        • Verle R.
                          • March 1, 1989
                          • 1163
                          Thank you,
                          Verle
                          • Larry S.
                            • 204
                            Thanks for all the response. Yes, I am interested in how you measure fuel pressure on the 327-375 F.I. setup.
                            • Larry S.
                              • 204
