SBC Oil Pan Gasket - NCRS Discussion Boards
SBC Oil Pan Gasket
  • Rod Wagner #27060
    SBC Oil Pan Gasket
    I saw a post a week or so ago referencing an oil pan gasket for a small block with a thicker front seal due to the size of the radius on the front of the oil pan (apparently, the chevy replacement pan has a bigger radius). Does any one have a part number for this gasget?
    Thanks in advance
    Rod
    • 43221
    Re: SBC Oil Pan Gasket
    Rod-----
    The part number for the complete GASKET SET is GM #14079399. The part number for just the thick front seal as a separate piece is GM #12337940.
    The part number for the one piece Fel-Pro gasket for the application is OS-34510-T.
      • 43221
      Rod-----
      • Roy B.
        • February 1, 1975
        • 7044
        C1's
        • Roy B.
          • February 1, 1975
          • 7044
          C1's
