1970 rear end color - NCRS Discussion Boards
1970 rear end color
  • Mike G.
    • July 31, 2002
    • 709
    1970 rear end color
    will i lose points if i spray the rear pumpkin cast gray? i think the book shows natural but it was naturaly cast gray. it looks bad and needs something. also what should i do with the rear spring? paint them the same cast gray? what do people normally do?
    • 43221
    Re: 1970 rear end color
    m-----
    Yes, you'll lose points if you paint the "pumpkin". Two choices:
    1) Thoroughly clean the "pumpkin" by bead blasting or shot peening (requires disassembly). Then:
    a) coat it with a light coat of satin finish clear which MIGHT not be detected;
    b) coat it with a product like Pre-Lube 6. This shouldn't recieve a deduct but you'll have to re-apply it from time-to-time. Not really a good choice for a driven car.
    2) Paint the "pumpkin" with VHT high temperature cast blast (the most "natural" looking cast iron paint I've found). This will merit a deduct, but it will look good and be durable.
    Which one do I use? Why, (2), of course.
      • 43221
      m-----
      • Gary R.
        • April 1, 1989
        • 1798
        Joe,
        I use Seymour high temp cast blast, have you ever used it to compare? I haven't tried the VHT.
        • Gary R.
          • April 1, 1989
          • 1798
          Joe,
            • 43221
            Gary------
            No, I don't think I've ever used the Seymour cast blast product.
              • 43221
              Gary------
