1967 Sunvisors - NCRS Discussion Boards
1967 Sunvisors
  • Kirk McHugh
    1967 Sunvisors
    Anyone have a good way to tighten the 67 sunvisor screws so they hold. Mine work loose and then blow down when I put the top down. They just don't want to tighten up any more. Any suggestions using the stock setup?
  • George Schaerer
    Re: 1967 Sunvisors
    A trick i used to solve this problem on our '88 Convertible is, believe it or not, is a plastic soda straw. Find a relatively thick wall straw that is a snug, not tight, fit on the visor pins. Insert the straw in the visor and counter sink it about 1/4 in, replace the visor on the mounting rods and tighten as desired.
    We did this a few years ago and the visors have worked fine ever since.
    Good luck and good driving.
    George and Sue Ann Schaerer
    '66 Milano Maroon SB Convertble
    • George Schaerer
      Re: 1967 Sunvisors
