C-3 70 ls-5 distributor questions Vacuum Can - NCRS Discussion Boards
  • Mark Z.
    • March 1, 2004
    • 48
    I had to pull my distributor to replace a broken valve guide and before I reinstall would like to clean it up. Is it a natural finish or painted? Also, the old vacuum is not working and will need to be replaced. The number on it is 217 16. What is a aftermarket replacement number? Thanks
    • 15674
    Re: C-3 70 ls-5 distributor questions Vacuum Can
    Without knowing the specs (if you have a CSM, how about listing them), I would recommend the same one as is best suited to non-ported vacuum advance big blocks, which is the NAPA VC1765 or equivalent, 0@6", 16@12", and a assuming your LS5 has ported vacuum advance, convert it to full time, and bypass the TCS if so equipped.
    The '70 LS5 is basically a stroked L-36 - same camshaft - so basic idle vacuum characteristics, which determine the best suited VAC are essentially the same.
      • 15674
      • Mark Z.
        • March 1, 2004
        • 48
        Duke,
        I'm taking a shot in the dark that you are asking for cam specs. (CSM) The GM part # on the tube is 3904359 that the cam came in years ago. I have been using the TCS system and haven't had any overheat problems unless I was hotlapping in final rounds at track in summer. When I was trouble shooting the valve guide problem I had 14.5" to 15" at the manifold @ 625 RPM.
        Is the dist housing outside the intake painted black?
        • Mark Z.
          • March 1, 2004
          • 48
          Duke,
            • 15674
            No I was interested in the VAC (vacuum advance control) specs, which should be in the specs section of the CSM, Section 6Y.
            The ...359 camshaft was used in L-36/68, LS5 from '67 to '73, and it does not have a groove in the rear journal.
            Your idle vacuum is about right for that cam, and a 12" VAC will comply with the "2-inch rule" with full time advance.
            Ported vacuum advance/TCS will not have any effect on hot-lapping since the engine spends most of its time at high throttle/low vacuum, but it will cost in fuel economy during normal road operation, especially in town.
            If your car doesn't have to be emission tested, I would convert to full time vacuum advance and bypass the TCS. There are probably creative ways of doing this without actually removing the system, so you maintain OE appearance.
              • 15674
              • Mark Z.
                • March 1, 2004
                • 48
                Duke,
                Sorry about that. Specs are 0 @ 8" and 15 @ 15.5"
                • Mark Z.
                  • March 1, 2004
                  • 48
                  Duke,
                    • 15601
                    Mark,
                    The distributor (the outside of the metal part above the intake) is painted a semi-gloss black. There is a color blotch on the housing that is unique for that distributor part number. The color is listed in the NCRS Technical Information Manual & Judging Guide (TIM&JG).
                      • 15601
                      Mark,
                      • Mark Z.
                        • March 1, 2004
                        • 48
                        Thanks I knew about the grey dot from the JG but didn't know if the black was flat or semi.
                        • Mark Z.
                          • March 1, 2004
                          • 48
                          • William C.
                            • May 31, 1975
                            • 6037
                            Semi, leaning to the glossy side.
                            Bill Clupper #618
                            • William C.
                              • May 31, 1975
                              • 6037
                              Bill Clupper #618
