454 oil pan drain plug - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 476
    Could someone tell me what the correct oil drain plug looks like for a 1971 454, head marking, size, magnetic or not, finish.
    Thanks in advance.
    Sheldon
    • 15601
    Re: 454 oil pan drain plug
    Part of the answer:
    Not magnetic. Painted red/orange like the oil pan.
      • 15601
      Part of the answer:
        • 43222
        Sheldon------
        Flanged "indented" hex head with 9/16" across-the-flats (wrench size) and 1/2-20 thread size. 3 lines on head (SAE grade 5). Common headmarkings were "A" or "M" and there may well have been others.
        With the possible exception of headmarking, you can still purchase one just like the original from GM under GM #3921988.
        By the way, the original gasket was a whitish nylon washer.
          • 43222
          Sheldon------
          • Mark #28455
            Junkyard or machine shop
            It's the same oil drain plug used on millions of Chevy V8 engines in that era - not hard to find, usually for free.
            Mark
            • Mark #28455
              Mark
