69 7029215 carb - NCRS Discussion Boards
69 7029215 carb
  • Brad S.
    • July 31, 2005
    • 227
    69 7029215 carb
    I have a restored 7029215 carb but the number reads 29215EH with a date of 0219. Why is th "70" not stamped. The rebuilder said sometimes the 70 was not stamped.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 69 7029215 carb
    is it a Qjet manufactured by "CARTER"? that could explain it. i have seen them with different numbering system
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: 69 7029215 carb
      • Brad S.
        • July 31, 2005
        • 227
        Re: 69 7029215 carb
        Clem, It is a "Rochester Quadrajet" . I also have a Carter built quadrajet and it is cast saying "Mfd by carter carburetor" then below it has the Quadrajet script. I believe it was a replacement carb and it does have a differant numbering system.It reads 4850S and F2 below that.
        • Brad S.
          • July 31, 2005
          • 227
          Re: 69 7029215 carb
          • Mark #28455
            see old restorer article by Mark Smith
            About 5 or 10 years ago, Mark Smith wrote an article describing Carter vs. Rochester made Q-Jets. In addition, he showed what percentages of each were in his large stockpile - interestingly enough, some carbs appeared to be ONLY made by one manufacturer. If that's the case for the 215 carb, then it may be a restamp. Who knows!
            Mark
            • Mark #28455
              Mark
              • Dick W.
                • 10483
                Re: 69 7029215 carb
                If you will read the NCRS 1968-69 Technical Information Manual and Judging Guide it explains the differences in the numbering and coding of the two carburetors. Rochester and Carter built carburetors are used interchangeably thru out the model years.
                Dick Whittington
                • Dick W.
                  • 10483
                  Re: 69 7029215 carb
                  Dick Whittington
                  • Brad S.
                    • July 31, 2005
                    • 227
                    Re: 69 7029215 carb
                    Thanks Mark And Dick, After reading the 68-69 Judging manual again It states " some wrer stamped at the plant with the last 5 digits of the GM part number" I have read this many times and guess brain fade took over again.. Thanks alot for your responses Brad
                    • Brad S.
                      • July 31, 2005
                      • 227
                      Re: 69 7029215 carb
