67 clutch return spring bracket - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    What does this look like? I have a plate measuring about 1 inch wide bent in a 90 degree angle, the long side is about 1 1/4 in long and has a hole in it big enough for the steering mast support mounting bolt. The short side measures about 3/8 in long and has a small hole in it. Is this what I am looking for?
    Thank you
    Randy
    • 43221
    Re: 67 clutch return spring bracket
    Randy-----
    What you describe sound like the piece. I can't say for absolute certain not having seen it, but your description sounds right.
      • 43221
      Randy-----
      • Ray G.
        • May 31, 1986
        • 1189
        Hello Randy;
        Two May cars have the bracket you describe.
        A November Corvette(4086) has a small plate w/ a hook for the spring to attach.
        Hope that helps.
        Ray
        P.S. Have not done pictures on this site, but will try if needed.
        I hope you dance
        • Ray G.
          • May 31, 1986
          • 1189
          Hello Randy;
          Hope that helps.
          Ray
          I hope you dance
            Here's a photo of the '67 clutch return spring bracket with the hole for the end of the spring; the pre-'67 bracket didn't have a hole - it had a little formed "hook" for the end of the spring.
              • Randy R.
                • March 1, 1983
                • 477
                Thank you for the replies. That is the piece I have.
                Randy
                • Randy R.
                  • March 1, 1983
                  • 477
                  Randy
