C3: rear brg tools - NCRS Discussion Boards
C3: rear brg tools
  • Steve L.
    • June 30, 2001
    • 763
    C3: rear brg tools
    There's someone that sells a set of these tools on Ebay for around $200.
    He's been selling these a lot.
    Are these tools good enough to do one rear end?
    Steve l
    73 coupe since new
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Phil P.
    • April 1, 2006
    • 409
    differential or outer swing arms ? *NM*
    • Phil P.
      • April 1, 2006
      • 409
      • Steve L.
        • June 30, 2001
        • 763
        Re: differential or outer swing arms ?
        Swing arms
        Steve :/
        Steve L
        73 coupe since new
        Ottawa, Canada
        • Steve L.
          • June 30, 2001
          • 763
          Swing arms
          Steve :/
          Steve L
          73 coupe since new
          Ottawa, Canada
          • Gary R.
            • April 1, 1989
            • 1798
            The tools I use for trailing arms are:
            Spindle knocker
            set up tool
            Bearing puller
            20 ton press
            some tools I made up
            200 ft/lb torque wrench
            Access to a surface grinder- very important to dial in shims and set endplay to .002" +/- .0005"
            Tools I don't use are the spindle installer and spindle press. Have both never used either one.
            Use a good quality grease and Timken bearings. You may find Timkens sold at the chain stores come from a off shore location compared to ones supplied by a bearing distributor. The ones I have seen at the chain say Poland on them, the ones I get from my supplier still say USA on them.
            Good luck with your rebuild.
            • Gary R.
              • April 1, 1989
              • 1798
              Spindle knocker
              set up tool
              Bearing puller
              20 ton press
