C3: Number 1 Xmember belly pan replacement hints - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    I'm replaceing this piece of sheetmetal. I noticed there are a number of spotwelds from the pan to the frame. The new piece I have has no holes in it. I was wondering if I should drill out holes in the new piece in the same positions as the spot welds and just plug weld?
    Any other suggestions in replacing this piece?
    Steve L
    73 coupe since new
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Verle R.
    • March 1, 1989
    • 1163
    Re: C3: Number 1 Xmember belly pan replacement hin
    Steve,
    Spot welds do not require a hole. If you do not have spot weld equipment you may have to drill a small hole and plug weld.
    Verle
    • Verle R.
      • March 1, 1989
      • 1163
      Steve,
      Verle
      • Terry F.
        • September 30, 1992
        • 2061
        Are you talking about the front crossmember under the engine? What is wrong with yours? Terry
        • Terry F.
          • 2061
          • Steve L.
            • June 30, 2001
            • 763
            It's rusted out in the middle.
            The frame is stripped and on a frame rotissarie
            Steve L.
            Steve L
            73 coupe since new
            Ottawa, Canada
            • Steve L.
              • June 30, 2001
              • 763
              Steve L.
              Steve L
              73 coupe since new
              Ottawa, Canada
              • Terry F.
                • 2061
                Thats a bummer. I make the tool for pulling the dent from the underside of the of the front crossmember. But, it won't help you with rust. I know what you are talking about with the holes. Going from my memory.....the bottom pan was tack welded in place in several locations but I seem to recall the holes in the pan also and it was stick welded in those areas. Unless you have a giant pinch welder, I would try to similate the electric welds. Not too tough to do. Good luck, Terry
                • Terry F.
                  • 2061
                  • Terry F.
                    • 2061
                    I read your post again. I would do as you say, drill and plug weld it in place. Clamp it down with vise grips and C-clamps then attack it with a wire feed. Should look real nice. Terry
                    • Terry F.
                      • 2061
