C-3 hood clearance - NCRS Discussion Boards
C-3 hood clearance
  • Rex T.
    • December 1, 1984
    • 455
    C-3 hood clearance
    I realize that this may be a rather strange question, but can anyone tell me how much clearance there is between the tallest point on a big block valve cover and the inside of an L-88 hood on a 68 Corvette?
    As always, thanks in advance for your help and best wishes to all for a safe and happy Thanksgiving.
    Rex
    • 43241
    Re: C-3 hood clearance
    Rex-----
    I don't know what the dimension is. However, the dimension should be the same as that between any big block engine valve cover and a standard big block hood. There is no difference in the hood height in the area above the valve covers between the regular big block hood and L-88 hood and, of course, the valve cover configuration affecting height is the same for all stock big block valve covers.
      • 43241
      Rex-----
      • Jim K.
        • August 31, 2000
        • 554
        If you are trying to measure it, try a loosely crumpled ball of foil inside a plastic baggie taped to the valve cover, close the hood then open it and measure what you have. Crude but effective.
        • Jim K.
          • August 31, 2000
          • 554
