C2 Original waterpump fasteners survey - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3162
    All, Do you have a "non molested" original waterpump on your C2 BB or SB?
    If you do.... are the fasteners holding the plate cover on the back of the waterpump hexhead or screw slot?
    Thanks in advance for your response.
  • Barbara S.
    • April 30, 1981
    • 599
    Re: C2 Original waterpump fasteners survey
    Steve. On my original '65 pump, they are all recessed hex heads. I'm about to send it in for restoration, so let me know if you want photos of the original pump.
    Best,
    Tony
    • Barbara S.
      • April 30, 1981
      • 599
      Best,
      Tony
      • Dale S.
        • November 12, 2007
        • 1224
        March 30th build 67 hex head. Dale
        • Dale S.
          • November 12, 2007
          • 1224
          • Gerard F.
            • June 30, 2004
            • 3806
            Steve,
            Hex head on mine 67 small block 608 pump:
            First time off, pump is dated F227. Here's the back:
            There was a post on this within the last 4-6 weeks. Some years and other models had the slotted screws.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Gerard F.
              • June 30, 2004
              • 3806
              Steve,
              Jerry Fuccillo
              #42179
              Jerry Fuccillo
              • Stephen L.
                • May 31, 1984
                • 3162
                Tony, please send a photo.
                I tried to send you an e-mail but it was rejected... did you change your e-mail address?
                Thanks.
                • Stephen L.
                  • May 31, 1984
                  • 3162
                  Thanks.
                  • Kent K.
                    • December 1, 1982
                    • 1139
                    Steve ---- Mine may not be unmolested, however, I believe all original fasteners were reused. My '67 is a Feb 14th (+/-) built and has hex-recessed-head screws with, what looks like a 'C", "D" or "O" mfr's marking.
                    Regards, Kent Keech
                    Future Lung Cancer Survivor
                    Kent
                    NCM Founder - Member #718
                    • Kent K.
                      • December 1, 1982
                      • 1139
                      Regards, Kent Keech
                      Kent
                      • Loren L.
                        • April 30, 1976
                        • 4104
                        What year are you asking about? In a five
                        year period, usage could have changed a # of times? You CANNOT use '67 data/facts to examine '63's, which have enough "running changes" during the model year to make them a topic all their own.
                        • Loren L.
                          • April 30, 1976
                          • 4104
                          • Nick Culkowski
                            Steve,
                            The issue of fasteners and associated back plate configuration on '67 water pumps was discussed here within the last few months.
                            The consensus and evidence seemed to conclude that on small blocks, recessed hex head screws with external tooth lock washers were used. The plate configuration along the perimeter was thought to be smooth with a slight up turn at the edge.
                            The big block original configuration was depicted as the same with an exception of the faster head being pan head and slotted, with a similar lock washer.
                            Gerry and Joe provided excellent photos of each example.
                            It would be interesting to note exceptions found on known original factory installed examples...
                            • Nick Culkowski
                              Steve,
