C1 '58 Engine Cross Mount Bracket - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    Does anyone have documentation on when the design for the front engine cross mount bracket changed to add the relief for the right hand freeze plug? In the judging manual it indicates "sometime around the 1959 model changeover". I have a very late '58 (#9128) with an early July assembly date engine so I'm trying to determine if either is "correct". It currently has the one with the relief for the freeze plug, with no cutout for the waterpump, so if the redesign was ahead of this I'll probably leave it alone. Thanks again, Ted
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Ted, I restored a mid 8000 VIN 1958...
    ...and was somewhat surprised to find it had a freeze plug relief style front cross mount. It appeared original to the car and that's the way I left it.
    • Dennis C.
      • January 1, 1984
      • 2409
      • Dennis C.
        • January 1, 1984
        • 2409
        Ted, Correction: It was a mid 6000 VIN 1958... *NM*
        • Dennis C.
          • January 1, 1984
          • 2409
          • Ted S.
            • January 1, 1998
            • 747
            Re: Ted, Correction: It was a mid 6000 VIN 1958...
            Dennis, did you take the car through judging? If so, did it cause any point deductions?
            • Ted S.
              • January 1, 1998
              • 747
              • Dennis C.
                • January 1, 1984
                • 2409
                Yes, I took it through judging, but it was a...
                ...while back. Duntov Award @ 7 Springs, PA. Scored 99.5 - then went to the drag strip with it...
                Cross mount was a no deduct. Had it been, no problem, I was honestly convinced it came with the car when new and I wouldn't have changed it regardless of some judging decision or point loss.
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  • Mike M.
                    • May 31, 1974
                    • 8396
                    Re: Yes, I took it through judging, but it was a..
                    can't seem to recall who beat yer white 58 fi vette at the drags associated with 7 springs nationals. can you refresh my feeble memory? mikie
                    • Mike M.
                      • May 31, 1974
                      • 8396
                      • Mike M.
                        • May 31, 1974
                        • 8396
                        it just hit me who outran the white 58. wasn't there a # 14 on the doors of the victor? mikie
                        • Mike M.
                          • May 31, 1974
                          • 8396
                          • Dennis C.
                            • January 1, 1984
                            • 2409
                            #14 is hallucinating... The "Beast"...
                            ...has taken charge once again... Be patient with him during these times of confusion.
                            • Dennis C.
                              • January 1, 1984
                              • 2409
