66 - Water Pump GM # 3859326 - NCRS Discussion Boards
    • 43222
    Re: 66 - Water Pump GM # 3859326
    john-----
    Yes, the '326' waterpump castings were used in Corvettes. I expect that all that were used for Corvettes were cast at Saginaw. However, I don't know that all of these ever had an "S" foundry mark. Some did, but I don't know that all did.
    The '326' castings were used for SHP small blocks (i.e. with aluminum manifolds) from 1965-67. According to some accounts, they may also have been used as early as 1963 for SHP small blocks. I doubt it but I wouldn't completely rule out the possibility.
    The '326' castings used for Corvettes had the bypass fitting tapped for 1/2" NPT. Many later examples of the '326' are tapped for 3/4" NPT. Bushings are commercially available to reduce the 3/4" to 1/2". Properly and cleverly installed and after pump painting (all small block pumps were painted with the engine), I would defy anyone to discern that a bushing was installed.
      • 43222
      john-----
      • Joe R.
        • March 1, 2002
        • 1356
        #18
        A guy in my chapter who has a 67 L79 got a correctly dated rebuilt pump with the small bypass from Long Island Corvette. Might be worth a call to see if they have one that would work for you.
        • Joe R.
          • March 1, 2002
          • 1356
          #19
