C3 Vacuum Advance Spring Clamps - NCRS Discussion Boards
  • Jack Corso
    On pg. 56 of the 68-69 Technical Guide, it states that there are spring clamps on the vacuum line at the card and at the vacuum advance. Is that correct?
    • 43221
    Re: C3 Vacuum Advance Spring Clamps
    Jack-----
    I don't know if any cars originally had the spring clamps on the vacuum advance line. However, I can tell you with certainty that my original-owner 1969 never had any clamps anywhere on this line, either at the distributor vacuum control, at the junction between the rubber line and the steel line or at the rubber line to the carburetor. Also, the AIM's show no clamps being used.
    There is a spring CLIP used, though. It mounts to one of the right side manifold bolts and retains/positions the steel vacuum advance line. It's available in reproduction.
      • 43221
      Jack-----
      • Jack Corso
        Thanks, I did think there were any. They would be quite smaller than any other spring clamp that I have come across.
        • Jack Corso
