67 C-2 splash panels - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    I removed the splash panels for the first time for a well deserved cleaning.The one on the passenger side has a slight "V" type bend in it from the front bolt hole back to about the middle of it. I does not appear to have been hit. Is this correct or is it flat like the drivers side? Maybe it was off before 1971? A picture of an original might help. Dale
  • Bill W.
    • November 1, 1977
    • 402
    Re: 67 C-2 splash panels
    Howdy Dale, Both splash shields should be flat. Sounds like these are original, if so you can probably save the bent one with a little hammer work and a vice. Good luck. Bill
    • Dale S.
      • November 12, 2007
      • 1224
      Thanks Bill, Will straighten. Joe Abbin had a nice get together at his shop here in Albuq. Send me your email address and I will foward pictures. D/
      • Joe R.
        • March 1, 2002
        • 1356
        Hi Dale:
        If your car has an AO Smith body, you may find the body job number on the firewall side of the passenger side footwell. This area is exposed when you remove the splash panel. So, if you clean the footwell surface, do so carefully.
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Dale:
          • Dale S.
            • November 12, 2007
            • 1224
            Thanks Joe, It is a St. louis body. Dale
            • Dale S.
              • November 12, 2007
              • 1224
              • Eugene B.
                • May 31, 1988
                • 710
                Dale,
                A little more research and info from Bow tie cars might be appropriate before beating the panel flat. My original '65 passenger side shield has a similar "V" shape to it. The driver's side is flat.
                Gene
                • Eugene B.
                  • May 31, 1988
                  • 710
                  Dale,
                  Gene
                  • Dale S.
                    • November 12, 2007
                    • 1224
                    Gene , Thanks for the heads up. I think I will repost this to get other owners to post on it if I dont get more responses. Any other comments or pictures? Thank you in advance. Dale
                    • Dale S.
                      • November 12, 2007
                      • 1224
                      • Gary B.
                        • February 1, 1997
                        • 7024
                        Job number same place of St. Louis cars
                        Dale,
                        My St. Louis built '66 has the job number on the fire wall exactly where Joe says it is on AO Smith cars.
                        Gary
                        • Gary B.
                          • February 1, 1997
                          • 7024
                          Dale,
                          Gary
                          • Dale S.
                            • November 12, 2007
                            • 1224
                            Thank you , I will take a look and post. Dale
                            • Dale S.
                              • November 12, 2007
                              • 1224
