54 door pulls - NCRS Discussion Boards
54 door pulls
  • Bob T.
    • May 31, 2004
    • 20
    54 door pulls
    i have a set of door pulls from a early 54 with only three screw holes, the ones i see for 54 have 4 holes, would an early 54 carry over with 53 parts, i see three holes on the 53 pulls, thanks for the input, bob
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: 54 door pulls
    Yes, early 54's use the 3 hole pulls.
    My old 54, #659 had 3 holers. Chuck
    • Kent K.
      • December 1, 1982
      • 1139
      Re: 54 door pulls
      My ol' '54 #1362 had 3 hole door pulls.
      Kent
      Kent
      NCM Founder - Member #718
      • Kent K.
        • December 1, 1982
        • 1139
        Re: 54 door pulls
        Kent
        Kent
        • Verle R.
          • March 1, 1989
          • 1163
          Re: 54 door pulls
          My grandpa had a 2 holer out back. Never saw much use for a three holer.
          Verle
          • Verle R.
            • March 1, 1989
            • 1163
            Re: 54 door pulls
            Verle
            • David K.
              • February 1, 1976
              • 592
              Re: 54 door pulls
              Yes, but the hole in the middle, is usually about 1/2 size.
              • David K.
                • February 1, 1976
                • 592
                Re: 54 door pulls
                • Brett H.
                  • January 1, 1996
                  • 367
                  Re: 54 door pulls
                  The three hole version vs the four hole looks a little different on the back side. If you ever have the chance to compare, you'll see a difference in the structure. converting to and from 3 to 4 hole is pretty easy also. Repro spears will be hollow in the back. The area where you actually pull, is different on the repros also. You can make them feel and look correct with a little work.
                  Just my experiences.
                  Brett
                  • Brett H.
                    • January 1, 1996
                    • 367
                    Re: 54 door pulls
                    Brett
