1966 427 390 Leaf Spring - NCRS Discussion Boards
  • Tony C.
    • February 29, 2008
    • 117
    Hi
    How can I tell the difference between a original or repro 9 leaf rear spring for a 1966 427.
    Thanks Tony
  • Gary B.
    • February 1, 1997
    • 7054
    Original 9-Leaf Spring
    Tony,
    Find someone with a known original mid-year spring and study the up-turned ends on leaves 2-9. No repro spring has the correct configuration of the upturned ends. The differences are obvious once you know what to look for.
    Gary
    • Stephen L.
      • May 31, 1984
      • 3162
      Re: 1966 427 390 Leaf Spring
      Here is an over-restored original 67 427/390HP spring.
      • Gary B.
        • February 1, 1997
        • 7054
        Steve: Nice photos! *NM*
        • Wayne M.
          • March 1, 1980
          • 6414
          Another possible identifier: "GLS" forging
          Check back to this archives link:
          I show a pic of the Great Lakes Steel ident on the edge of the 3rd leaf down. This was one (the only ?) supplier for these spring assemblies.
          Just 20 minutes ago, brushed off the grime on the 4th leaf down and there it is again. This is on a July '65 car. I believe the conclusion was that it's location is entirely random, with the roll stock that was fed into the cutting machine having this symbol every so often. Where it/they ended up on the spring assy was arbitrary.
            Re: Another possible identifier: "GLS" forging
            Wayne -
            I believe that the "GLS" was embossed in the edge of the raw strip stock by the strip stock supplier (Great Lakes Steel) during its run through the rolling mill, not by the spring supplier (Ontario Steel Products or Rockwell).
            • Gary B.
              • February 1, 1997
              • 7054
              GLS forging; not on most
              Wayne,
              I've examined and dismantled 5 or 6 original GM spring and I've only seen the embossed letters once, so I don't think most springs will show the embossing. The upturned ends is by far the easiest way to detect original GM from repro.
              Gary
              • john daly
                Re: GLS forging; not on most
                If you have access to past Restorer magazines Gary has authored (co-authored ?) a couple of comprehensive articles on mid year leaf springs.
                jd
